Wrap Text along circle
10048.9 In reply to 10048.8
Hi Lara (Mala),
The base line (or base surface), is created by the user to guide the placement of the text.
For your torus surface case, the base should (most likely) be a base surface.
So make a plane in proximity to your text. The plane is the base surface.
So the user may have to do some math to get the size of the plane rectangle, versus the surface dimensions of the torus, to guide where the text is "flowed" to. This is where unwrap of the two radii of the torus could help with plane dimensions times desired fraction. Also PI * 2* some radius could help.
Sizes of base line or surface, and placement at a base of the text, (Either the bottom of the letters, or the backside surface of the letters,) and point selected on torus, all influence the final result.
Like Burr says, the text can be lying on top of the base surface, or standing on top of the base surface...( or base line)
EDITED: 6 Dec 2020 by BEMFARMER
