To label a point in a drawing, run the PointCoordinates3 script to place the (x, y, z) coordinates on the clipboard. Exit command.
Run the Leader command to place leader, select Done, then press Ctrl+V to paste the (x, y, z) coordinates into the leader options window.
Hit backspace to undo the auto enter (cr/lf).
This could also be done in the details window of dimensions.
I think that I will modify PointCoordinates3 to add the () parentheses, and remove the cr/lf.
Attached is a quick modification of a script. Maybe someone could make a better shortcut key.
