Hey wisty,
What you need here is merge (boolean command). Check out your line, there are two points in weird positions, if you inspect them (show points) you will see that your line has a portion that is "double", these points are folded. If you delete one of them (select and delete), merge command completes successfully here.
Let me know if this solves it!
