I can't Boolean Diff these two solids
10043.6 In reply to 10043.5
Awesome result Ed, and Frenchy touched on where I was going.
Basically, break it up into sections that can array to make your chain. As long as it is uniform... which is how I did this model.
The half solids booleaned together, then could boolean out of your block.
In case it's not though, I wanted to add one more part.
I swept only a half circle. This would allow me to remove the top surface of the half sweep, trim out the inner, unwanted walls (Separate and trim parts with parts), then I could have the half shell, essentially what a boolean diff would produce. Then I just have to build the boundry surface, with some type of shape and planar...
Then you could flow.
Anyway, thats one added point to Frenchy's point...
Ed's original file is Heart Boolean Diff.....
