I can't Boolean Diff these two solids
Thanks Michael -
Yes, that does work and I remade my model as below.
I first performed a Mutual Trim on my curve, took a short section shown in green, Mirrored it, Copied, and Joined to make the longer green & red chain. Then I performed a Sweep on each colored section and Boolean Union into a solid. Then I Flowed the design around the ring and Boolean Diff.
I made no attempt to match up the ends, as they are on the bottom of the ring, and this model is for rendering, not mfg. When I make the ring on a rotary table on the milling machine, the ball-nose cutter follows long continuous curves to produce the grooves. These curves match up on the ends for a seamless design.
Thanks again Michael, BurrMan & Pilou. I'll be making similar designs in the future and now I have a process for making the models.
