What plug-in can quickly change a quadrilateral to two triangles? A contraction point is formed after subdivision
10014.2 In reply to 10014.1
Hi hl, hmmm well something like a scripted export to OBJ format with "triangles only" to a specific filename, then using Max's _ImportOBJ to read it back in again could work.
But I can probably cook up one for you that extracts 3 lines and makes a planar surface out of them.
What rule do you want for which diagonal to choose, should it be the shortest one?
I can take a look at doing that tomorrow.
