V4 beta Oct-27-2020 available now
10011.72 In reply to 10011.66
Hi Mik,
> It would be great! Do you mean that final 3DM will contain merged objects in 4 views + block
> template and then we can start with dimensionsioning or exporter will generate PDF with 4
> views + block template, then we import PDF into MOI and start dimensionsioning?
So I mean more like this - you have your model you've made in one file, and a title block template set up in a separate file. Now go ahead and add in dimensions on your model. Then you export to PDF and there is an option for the view configuration. It would have options for "Top", "Front", "Right", "3D" (all single view drawings as it is now), "4 views", or "Use title block template".
If you set "Use title block template", it would compose the PDF by pulling in your title block template file and looking through it for any rectangles that have been given an object name of "Top", "Front", "Right", or "3D" and when it finds those it will generate that view and put it inside there.
