V4 beta Oct-27-2020 available now
10011.53 In reply to 10011.47
Hi WN,
> I meant this: https://yadi.sk/i/hOZXJfOYyTzAVA
Ok, that helps me understand now. Yes, I'll look at fixing that up.
If I understand correctly, you can use a workaround currently to get the result you want. The workaround is to initially place the radial dimension inside the arc's center point, then turn on edit points for the dim and drag the text point out like this:
But yes, it would be good to be able to draw one like that directly, I'll take a look.
