V4 beta Oct-27-2020 available now
10011.111 In reply to 10011.110
Yes I understand the Rotate plane! ;)
but
< it doesn't make sense to avoid rotating the view
it's losted time! :) I f you see video of Chris or mine we can draw any dimension in any positions
without rotate the 3D view's so the plane! ;)
> Trick of the inclined selection avoid to rotate the view but there is no equal length of side lines...
> I suppose that is not visible if lines are same color than volume for print ?
Parts of Dimension who are overlapped will be not visible if all are black for example! :)
PS There is no thickness for dimension lines ?
EDITED: 11 Nov 2020 by PILOU
