V4 beta Oct-27-2020 available now
10011.102 In reply to 10011.100
Hi Michel,
> Will the "Ortho views only" hide, for example, the "Front" dimensions to appear as lines in the "Top" view ?
> I mean just like the "thickness" of "Images" placed in the "Front" view are invisible in "Top view".
I was thinking "Ortho views only" would have the same behavior as current ortho views. But there could be additional settings to limit it to just one ortho view. Maybe:
Show in: "All views", "Ortho views only", "3D view only", "Top view only", "Front view only", "Right view only".
> Would there be a "View" property of a Dimension that makes it belong to a view ?
Yes this would be a setting for a dimension to be displayed only in certain views so you could control generating a multi-view PDF file better.
> Would it be interesting to have that script included in the dimensions Pane ?
Yes that seems like it would be good.
> The only thing I would like to be added to it would be to act like placing an Image
> (I mean letting the user choose (click) where the 2D should appear in the 3D space).
They are selected when the command ends so you can position them using Transform > Move or dragging them. Maybe there could be an option to generate it inside a rectangle with a specific object name similar to how a title block template could work.
