AutoRotate script final
1001.3 In reply to 1001.2
Yes, it is fun playing with MoI's scripting once in a while - this little script has turned into a good learning tool for figuring out how to customize MoI. The way you've got it all designed, the possibilities are pretty wide ranging - it wouldn't surprise me to see someone at some point in the future implement a completely different, customized, gui and function set for MoI, (not me tho :) )
Thanks for the comments, Michael, I think I'll play around a bit with your suggestions this evening.
I was kind of wondering about the effect of machine speed on the rotation loop, my current machine is an old PIII 866 and the rotation goes plenty fast on it, but like you say, a faster machine would probably spin a model like a top!
One sort of interesting side effect of auto rotating a model is that the model rotates in one direction if it's centered in the middle of the viewport, but if you pan it off to the side, the perceived rotation reverses, because the whole viewport is actually rotating - sort of a fool-the-eye effect!
Paul
