Planar surface command
10000.4 In reply to 10000.1
Hi Marky, was this imported from CorelDraw using DXF format by any chance? If so there is a problem with how CorelDraw packages up the spline information in DXF format, it will be fixed up in the next upcoming MoI v4 beta.
For now use PDF format to transfer out from CorelDraw into MoI, that should work better and avoid the problem with control points stacked up on top of each other which is why those curves are not working well for you now.
